steined
- Dec 1, 2022
- 5
I currently have
4 12V 300AH LiTime
1 Magnum 2800 Watt inverter w/ 120 Amp charger
1 Victron 100/50 MPPT Solar charge controller
4 Newpowa 220W Solar Panels in series (880W)
1 Victron 500A Smart Shunt
I cannot run ACs, Cooktop (220V), Dishwasher, Washer, or Dryer with the current inverter setup.
I have room for 4 more 220W panels easy, and probably 6 -7 more to total from 8-11 panels total (1760-2420 watts flat mounted) (Can likely do more but may augment with some ground instead)
DO I
KEEP 12V
Replace Magnum and get 2 Multi Plus 2 12/3000 2x120 and run them in split phase and add more charge controllers?
Or
CONVERT to 48V
Get 2 Multi Plus 2 48/3000 and run them in split phase
Upgrade to 150/70 Victron @48v charging
Wire existing batteries in Series
Get a 48V to 12V DC-DC converter
Reasons I like the Victron
1.) Grid assist (sometimes we're on 15A or even lower outlets and we can use from AC and it will augment the load)
2.) Ecosystem is nice
Would an EG4 6000XP or some other all-in-one provide what I'm looking for with easy grid assist as well? Any other suggestions?
My power sources are 50A Shore and 48A 240 Generator into an auto transfer switch. That goes to Inverter/charger, inverter charger then goes through some mystery load management system and to the main breaker. If I presented 220 to the myster load management system it would likely think I'm on 50A and all would be well.
I think I have plenty of battery, just need more solar and inverter power to be able to live fully off grid w/ Washer/Dryer and some occasional AC use.
Thanks in advance!
4 12V 300AH LiTime
DO I
KEEP 12V
Or
CONVERT to 48V
Thanks in advance!
