Taken from the Renogy website: https://uk.renogy.com/renogy-rover-20-amp-mppt-solar-charge-controller/
6.How many watts can Renogy Rover 30 amp charge controller handle?
The Rover MPPT charge controller can work with standard off-grid 12/24V solar panels with high voltage or multiple panels with voltage up to 100V. And the maximum combined input solar power is 400W for a 12V battery system or 80W for a 24V system. In particular, this controller will significantly increase the efficiency of a solar system where the solar panel voltage is much higher than the battery voltage.
Is this saying you can use panels arrayed into 24v input but charging a 12v battery?
