Will these panels work with a Renogy Rover 60 amp charge controller to charge (2) 200 amp 12 volt lithium batteries? And if so, how many panels can I connect in parallel with this controller?
Charge controller will accept 150 volts.
Thank you, Andre.
Here are panel specs:
Cracked Vinyl Trina 230W Solar Panel
$20.00
Rated Power (Pmax): 230W
Maximum Voltage (Vmp): 29.8 V
Maximum Current (Imp): 7.78 A
Open Circuit Voltage (Voc): 37.0 V
Short Circuit Current (Isc): 8.26 A
Maximum system voltage: 600 VDC
Max Fuse Rating: 15 A
Thank you, Andre.
$20.00
