republicmachine
I'm new and have been gathering parts for the last year for an off grid set up. From the top, I have 10 used Solarworld 240w panels. These need to connect to a Victron 150/85 charge controller. My understanding was that this unit can take all 10 panels in a 5s2p configuration. I'm over my head a bit on how I should connect these two systems. Should I be looking for a combiner box to hook the two strings together then take the wires from the box to my Victron SCC? Should I have a suitable shut off/fuse/breaker DC rated for proper amps at the top of the combiner box for each of the two strings?
Panel specs
Panel specs
Performance Under Standard Test Conditions (STC*) | |||
| SW 240 | ||
Maximum Power | Pmax | 240 Wp | |
Open Circuit Voltage | Voc | 37.6 V | |
Maximum Power Point voltage | Vmpp | 30.6 V | |
Short-Circuit Current | Isc | 8.22 A | |
Maximum Power Point Current | Impp | 7.87 A |
