I recently started researching solar systems, inverter and battery systems so I could eventually be competent to setup an RV trailer to do some off-grid camping. I love to off-grid camp, however DW hates the generator and so do I! I camp mainly in the Adirondacks in NY, where there is a lot of forest cover and little opportunity to get peak sun on panels. I have a Forest River Shamrock currently that we use, however, eventually we are going to upgrade something different in the near future.
My dilemma now I have to use and configure my current TT and i want to get enough battery power to off-grid in my current trailer for a week, without the generator running. What I would like to get is two 200ah lithium batteries, run in parallel to camp off-grid for 5-7 days without charging. I looked at the power draws of everything on my trailer and I believe I have figured correctly that if everything is running in the camper, with the exception of the AC and microwave, I would be using approximately 100 watts an hour or roughly 8.33 amps. If I run everything 24-7, I would be using 200 ah. Not likely because I have never run everything at the same time. I figure an average of 50-70ah per day is what I realistically draw. The camper is not really adaptable to build a solar array and inverter system, so until I get a new TT I would like to add two, 200ah lithium batteries, battery shut off, Victron 712 Shunt and a solar suit case array to my existing TT.
My questions are:
1. If I am paralleling my two batteries and they are lithium 200ah; and charge and discharge at 50amps or less, can I wire the batteries in parallel with 6 AWG, or should I use 4 AWG.
2. Same question as above, but what should the wire size be to the shunt and battery cutoff?
3. Where should I fuse this system and I presume a 50amp fuse?
4. This may seem an obvious question, but if I am using a solar array suitcase with PWM, where do I hook up the terminals to charge? I assume to one side of the shunt and the other to the positive side of the battery? Anything else I am not seeing here?
Sorry if these questions seem incredibly basic.
Dave
My questions are:
Dave
