is it time to buy sodium cells instead of lithium?
at a quick glance, cost wise sodium 220ah cells seem to be a little cheaper compared to lithium 280's. link i found below,
weight wise, while it would add up building big banks, especially with sodium cells having reduced capacity. its not a mind blowing difference.
220ah sodium 4.5kg per cell
280ah lithium 5.35KG per cell
PROS
sodium has that extra layer of safety with no flammable electrolyte
charging at low temps -30C
3C to 5C discharging
and ability to discharge to zero volts without damaging the battery
CONS
has a reduced cycle count
voltage range doesn't match current equipment well
whats everyones views? is there pros and cons i dont know about?
cheers
PROS
CONS
cheers
Alibaba.com
www.alibaba.com
