wheeto
Hello,
I currently have two of these battery packs connected to a Victron MultiPlus-II 48/5000. They're connected together via CAN for closed-loop operation and work perfectly for Victron's ESS system with AC coupled solar.
Except
They discharge very unevenly, and cut out even when the BMS says that there is 20% capacity remaining. In order to start to get to the bottom of this problem, I removed one of the packs and have just one now connected to the inverter. Straight away I'm getting the battery BMS going into OCP and shutting down, even though there is no way the inverter can pull more than the 100A the pack is (should be?) capable of and the inverter thinks it's pulling way less than this anyway. See screenshots. Any ideas where I go from here?
Thanks,
Except
Thanks,
