Venezuela Solar
- Dec 6, 2019
- 146
Hi, where i live sun is up north half of the year and south the other half, we are very close to the ecuador line, so there is good sunshine all the year round but im thinking on mounting a rack of (4) 330 sunpower cells (80 inches long) in a way that i can change the orientation once a year, let me explain, the highest point of my roof is 10 meters, on that point ends the double fall roof, one fall faces north and the other face south, im planning on using one fall to place all modules and using a "triangle" to change their orientation to the opposite face (see pictures).
Would this will be worth it? Or should i just install then horizontal?
Should i place then with the long side parallel to E-W or parallel to N-S axis?
What would you advice? If i go with changing position i would have to go up to the roof 2 or 3 times a year and change the position manually
I will attache screen captures of an app called suncalc where you can see the azimuth and all the details, if i go with tha changing option i would have to know the angle to the horizontal and i dont really know how to calculate it
I would appriciate any help, thanks.
