SolarfortheOuachitas
- Aug 1, 2020
- 44
Hello,
I recently replaced a 12 volt 10 watt solar module with a 100 watt module to run my solar attic fan.
It seems that the fan runs faster with the new module and doesn’t require as much sun as the old one.
Am I causing any overheating problems by using the larger panel to run the fan?
Could it overheat?
I can’t find any specs online about the amp draw on the fan. It’s a big fan designed to help ventilate an attic.
Could it overheat?
