Indeed, finding a real professional is challenging task in the capitol, almost impossible at country side.
In Asia many people DIY as there is not a real other option.
If you build your house, most of the construction workers are rice farmers.
No offense, and some have become real craftsman.
Also many homes don't last 10 years....
Like I said in my PM, one of the problems is Corona lockdown that makes the shops closed
And apparently you are in a rush
There is always better product to find, almost none will make their rating.
And be advised that most China products are overrated.
Not bad, but don't think you can really use the 2000 watt on a 2000 watt inverter
You can use continuous 1000- 1500.
Same for panels
Theoretical maximum number watts production.
And most of them are not bad at all.
Will made a test with Flexible panels.
Expensive ones and cheap ones.
As most panels come from China and only get new label...
You don't have to be surprised about the results.
I bought mine at
www.9solarcell.com
Local Thai company.
Yes official closed as all none essential stores.
I'm sure that if I send them an email, I can order panels.
Just as sure as I am that there are similar local shops.
But can be hard to find.
Alternatively is China.
High Transport costs and possible broken glass.
Amazon or eBay have many products, transport costs are crazy.
In Thailand we have Lazada and Shopee China crap with some local sellers.
And those shops are still open.
If you can't use them in Philippines, you can do AliExpress.
Alibaba is good for cells.
AliExpress for BMS
AliExpress for solar things
Maybe even MPPT inverter.
MPPsolar have a good reputation.
EASUN is the brand responsible for frying my 16*200Ah deep cycle batteries. (Charge at 19.5v for 12v battery) I can NOT advice.
MPP SOLAR Official Store
MPP SOLAR Official Store - Amazing prodcuts with exclusive discounts on AliExpress Mobile
They can hook you up with the Inverter you need.
For your installation I would choose 24 system, +3000 watt inverter with possible parallel function (!!)
That way you can extend when needed.
For battery...
8 or 16x 120a. Lifepo4.
Daly BMS. (Proven quality), common port
solar..
depending on what you have left and on your priorities.
if you want to be able mostly during day and go in extreme low power mode at night..
8 x 120Ah and as much panels as possible.
if you don't want to go to that low power mode, 16x 120ah.
Refrigerator can be set at lowest temperature during day time and highest for the night.
Yes, you need to set every day, bit it saves tonnes in batteries.
For me, 152 * 16 was not enough for one air-conditioning (high energy efficient, 550w continue usage if it need to cool all the time.
Our refrigerator is low power also.
Only the refrigerator, the 152 would be enough.
Compare to your 16* 120 Ah.
If I like to use more ( and I do) I need more battery! "More is better"
For now I think 456Ah is enough.
That is 48*152Ah.
I have 27 panels.
Starting with 2..
Then 18
And now 27.
They give enough energy.
But together a shitload more then 2000 USD!!
The (now dead) deep cycle where $4500
The lifepo4 batteries alone are $2500.
BMS with balance will be together $300..
My Revo II 3.2kw 48v inverter was about $500, + $100 transport and tax (600 dollars)
One panel 105 USD + 10 transport
Mc4 connections about $50 (27 panels)
Cables, AC breakers, fuses, DC breakers, relays, emergency switches....
My emergency stop alone is +250 dollars.
Not really needed, but I care a lot about safety.
"While that might conflict with the cheap breakers I use..
Those are during the "move around" phase and work perfectly for this.
I need to disconnect cables and with breakers in between it saves me the sparks and are more safe.
They are double or triple the needed current and available.
Thailand doesn't have DC breakers in the hardware stores, except this cheap type.
At permanent setup, they will be replaced by better quality".
Freight is expensive.
Buying glass panels from any different country is not realistic at your quantity.
If you need a few hundred, sure! ...
Even with my 27 it was not realistic option.
If you can't wait, the flexible ones are the best bang for the buck and will last just as long as the glass ones!
And they are a lot lighter.
Better suited to put on your roof.
If the roofs are like Thailand...
Most can not support the additional weight of the glass panels.
One or 2, yes.
6 or 8?
Probably not.
(Thailand often have steel sheet roof, with just enough iron structure to carry the weight of the sheets.
As we have no snow, it's extra weight not in the planning.)
Good luck!!
24 or 48v will suit you better long term.
For all in one Inverter, the ones that can do parallel are easy to extend in later time.
If power during day is most important - many panels
If power during night is most important - many battery.
The rest is up to you.
Many wisdom and please share what you decide!!
The pricing on AliExpress is already low, but you always can try to get a few % off the price by contacting the seller.
I can advise the Revo II
Will can advise the MPPsolar
I read good stories about the GroWatt.
If you find your product, please do a search on the internet (Google, YouTube, Facebook, etc) for reviews of buyers.
They can help you decide.
I didn't do with my EASUN.. why I didn't? I still don't know...
That mistakee costs me $4500.
