Solar Dump tiny cabin
sun85
harwich
Hi There,
I have a Renogy Rover 40a MPPT controller charging 880a Lead acid batteries, with 700w of Renogy Solar panels.
Is there a way to wire in a Water Heater "dump load" to make use of excess solar?
if so what do i need to add or how do i change the settings if possible on the controller?
sorry im very new to all this, thanks in advance.
Doesn't come cheap I'm afraid
There may be other option though I am not sure
Hello and welcome to the forum!
There's a few threads about using excess PV to heat water but first we should talk a bit about your solar to battery ratio.
FWIW, from experience, I'll caution you might struggle to properly charge your batteries.
Generally speaking lead acid batteries in a cyclic application will do best with when they see amp of at least 10% of thier AH rating for charging. 880 AH x 10% = ~90 amps of charging.
What voltage is your system? How many batteries?
They are 110ah leisure batteries currently running 8 of them in parallel, and at 12v, im only running them down to 50% for obvious reasons.
system is powering a 80w wine cooler and 50w of fish pond equipment 24-7
I've aso wired in a Renogy 30a PWM which is controlling 300w of the system as all together it would be to much for my 1 MPPT controller
thank you for everyones replies
Hey sun85 out of interest , how are your 8 leisure batteries wired up ?
Are they all being drawn on / charged equally?
Hi Sam,
One controller is wired, battery 1 positive closest, and negative on battery 8
The other controller wired, positive on battery 8 and negative on battery 1
Hi Sam,
Ah I see . you've got it right to do it diagonally. 8 batteries is a lot of in parallel so always worth keeping an eye on the balance
Only one thing is , ALL connections to the battery bank should be made at the same two corners, not mix and match
SCC
Inverters
Mains charger
DC loads
everything , lugs stacked on battery 1's pos & battery 8's neg
Worth a read if you're interested:
I haven't personally, looks like a good cheap solution
Have a chat with bimble, they are nice people should be able to set you straight
If you get it working pls come back and share I'd be interested
How they are paralleled is important.
When I was running 8 fla’s I drew out a bunch of “options” that were possible.
In the end, 16 equal length cables or “4Px2” were the only practical way it made sense.
“Daisy chain” style arrangements leave the batteries in the middle neglected. And 800W isn’t quite enough to keep them healthy.
