In order to power my necessities when the power goes out, I am looking to put together a unit I can store in the garage with a battery charger and pull out when needed. It's not going to be a system that is used daily. I will take it on the road to supply portable power as needed for camping or parties, etc. I have a couple questions hoping to get so.e input.
1) Batteries. Lifepo vs FLA. I am torn. I will not use it daily so I have an issue with the cost. I do want to be able to store with a charger so the batteries are maintained. However, the weight is a killer. A 300 lb generator is not that portable.
2) 12v or 24v. Not sure. I will need some 12v charging receptacles so kinda hard to go to 24v just to add a converter to go back to 12v. Is it worth it? What about battery chargers?
3) panels? Since this will be portable, I need panels that I can take out of my garage and set up easily in the backyard. The Renolgy suitcase panels are interesting. The other portable kind you find seen cheap. I want about 400-800 watts. 200 wat panels seem manageable.
4) Finally, wind power. Yea, I know this is all about solar but wind turbines pic my interest. Generating power at night during low power usage and supplementing during the day when there is high usage interests me. Again, I would have to make the portable and set them up when needed. My question is regarding voltage. If you have the right controller, does the fluctuation in voltage/amps become an issue?
Thanks for your input in advance.
