G gaza2015 New Member Joined Jan 8, 2024 Messages 46 Location Walsall Apr 15, 2024 #1 Wiring solar panels like.one in photo need to no wire size i need running 6 panels wire is.about 10ft thanks Attachments Screenshot_20240415_094331_Chrome.jpg 96.9 KB · Views: 3
sunshine_eggo Happy Breffast! Joined Oct 26, 2021 Messages 17,658 Location HBR, USA (6500' in ENE AZ) Apr 15, 2024 #2 Isc = 9A per string Max fuse = 15A (also a good rule of thumb for sizing) two strings In parallel, 18A Most PV wire is 10-12awg. You can use either.
G gaza2015 New Member Joined Jan 8, 2024 Messages 46 Location Walsall Apr 15, 2024 #3 sunshine_eggo said: Isc = 9A per string Max fuse = 15A (also a good rule of thumb for sizing) two strings In parallel, 18A Most PV wire is 10-12awg. You can use either. Click to expand... So 10awg is.fine
