Back to my last question. I have connected 5 150 watt panels in series/parallel and am hooked up to a power inverter 1200W. I would like to know if I add more panels can they be 100watts or do they need to be the same wattage?
The knowledgeable members here would need specifics. What make and voltage is your inverter? Presumably you have a charge controller? Specs? You need to provide specifications on panels as well. Mixing different solar panels in a competent way requires some skill.
