Hi Im selling my 2011 Nissan Leaf with solar powered supplemental battery system. Would be good for an off grid situation, because it can be charged entirely off its own solar panels. The car has 5 total solar panels that combined total 600watts. The power goes to a big battery and inverter system in the trunk, that allows you to charge the car off the 7064 watt hour 12v batteries in the trunk. The details are listed here, but there is also a YouTube channel dedicated to the build of this car, where you can find much more info. The channel is (Innovative sustainable solutions) https://www.youtube.com/@InnovativeSustainableSolutions
Car info
2011 Nissan Leaf
Nissan Leaf with 66347 miles
Replaced main EV battery with a used one with 10 bars of life left
Clean blue Texas title
Solar setup info
The solar panels power a battery and inverter system in the trunk. The roof panels fold out revealing two more panels underneath. 4 roof Renogy 12v panels ran in parallel (175w, 160w, 100w, 100w). The one panel on the hood is a 65w.It has four 12 volt 1766 watt hour lithium phosphate batteries ran in parallelThe batteries are charged with a Renogy solar charge controller. The batteries are connected in parallel and connected to a 12v 4000w pure sine wave inverter. You can then charge the car’s main EV battery pack by plugging the cars charging cable, into the inverter. It car can be charged while the solar panels are charging the batteries, but it can NOT charge while driving. You can also charge the batteries in the trunk from a wall outlet, using an extension cord if you want.A small portable air conditioner is in trunk to keep batteries cool in the summer. It exhausts heat your rear door window. The air-conditioner is very low wattage and runs off the trunk batteries I am not the builder of this setup and the one who made the YouTube channel. I am the second owner since he built it. I can give you the builders contact, if you have any questions after buying it.
Im asking $9000 for it.
Im located in Dallas Texas. You can reach me at 214-808-9759 jasonkane4321@yahoo.com
Car info
2011 Nissan Leaf
Solar setup info
