ericfx1984
- Oct 10, 2021
- 801
So I'm in the process of setting my solar shed up... When the system first comes online it will have four MPP solar LV6548 inverters and two, 16s lifepo4 batteries, one of them is 304 amp hour the other one is 280 amp hour... Each of them will have a 200 amp smart BMS from jbd(or was it JBS?)
The shed has r13 in the walls, two layers of R5 hard foam in the ceiling with an air gap to allow air flow and will have one or two layers of EVA foam mat for insulation on the floor
Additionally the roof is shaded completely by solar panels which significantly lowers the heat load in the summer
I figure in the winter that the heat of the equipment running should be enough to keep everything nice and warm
But I do recognize that I could be wrong on that and I'm open to the idea of adding some type of heating
What I'm most concerned about is cooling... I do have a couple windows so I can easily add a small inverter air conditioner and just keep the temperatures lower than say 80 or 90° F?
But I thought a simpler option might be just to vent it during the hot months and allow the hot air to just leave through the gable vents by putting a fan with a closable vent in the ceiling?
Just curious what y'all's thoughts are
