G gaza2015 New Member Joined Jan 8, 2024 Messages 36 Location Walsall Jan 8, 2024 #1 Help please I've got 4 x 400 watt panels wiring in series volts go up amps stop as thay am running the wire 20 feet away which wire would I need to do that thanks would 10mm2 do it
S shvm Solar Enthusiast Joined Sep 16, 2023 Messages 216 Location UP, India Jan 8, 2024 #2 gaza2015 said: 4 x 400 watt panels wiring in series Click to expand... most 400 wp class panels ship with MC4 connectors and 4 sq.mm wires from factory. 10 sq.mm is probably overkill. You should be fine with 6 sqmm wire even accounting for long distance runs.
