Quick background:
Today around 845AM, with about 2100W, it just stopped working.
Fingings:
Now, there is still no response from the inverter.
I called Signature Solar where I bought it from and they were less than helpful.
Any advice?
- 7300W of panels
- 2 strings of 13ea
- TIgo TS4-A-O on all
- SolarCity Delta H6 Inverter
- Commissioned 3/11/2022
- 100% Designed and Installed myself
Fingings:
- Inverter showed "fault", but did not notice any lights (may have missed them)
- Backfeed breaker (40A) in main panel was tripped.
- After cycling DC disconnect and turning AC back on... no response from inverter.
- Power readings from Emporia showed power drop from 2100W to 800W for 19secs, then zero.
- Opened up the inverter to take a look. Both strings showing 475 Voc. 248V across L1/L2. Tested both fuses in the inverter and not blown.
- My Tigos did not shut down. They are still reading normal voltage (Voc).
Any advice?
