JGEnc
I purchased these modules used a couple of years ago for research for a commercial project. I have 8 from the same pack that have not been modified or used, and two additional ones that have been slightly modified with ANT BMS (bluetooth) and are wired to a high output split-phase (non-grid-tied) 48VDC 120/240VAC inverter. The system 2 w/BMS and inverter is only partially assembled and being sold as parts, as are the modules.
The modules have been kept in my garage at ~44V, with very little maintenance charging required.
They are the Samsung SDI 63ah prismatic cells in 12S modules. Each module is nominally 2.7kWh, so total nameplate for the 10 modules is 27kWh.
Looking for someone to locally pick up, ideally as a lot. If purchased all together my asking price is $1500 for the 8 plain +2 w/BMS modules and the split phase inverter. That's only $150 per module, with the two BMSes, chargers and inverter included. Encinitas, close to the 5. Please contact me to come check them out. Thanks.
