I've replaced the stock fans of my Axioma BFP 5600 inverter (which is also branded as Voltronix or Axpert) with Noctua A8 and have few tips for others to save time.
The noise level after replacement is very low, almost indistnguishable, while it was very loud before replacement.
I would say there are 3 major solutions for noise issue:
1) Use temperature PWM controller for stock fans.
+ cheaper
+ do not require unmounting of stock fans
+ max airflow kept the same
- will still be noisy under load
2) Use silent fan
+ silent under any conditions
- slightly more expensive (A8 PWM is $17 on Amazon, there is cheaper R8)
- may result in lower airflow
3) Move the inverter into separate building (not all can afford this). I have it installed in the garage which is isolated from the home by door, but the nosie was still bothering me.
I was going to do 1) and 2) but after installing silent fan there is no need for controller.
There is no need to use Noctua low-noise adapter (which lowers RPM and noise even more), as it will lower airflow a bit with alomost no impact on noise.
The biggest issue is the inverter connector which is 1mm thinner than Noctua, so I needed to cut the wires and use thin white connectors instead of Noctua black.
Also, Noctua pinout is different, basically I need to swap middle 2 wires while keeping the side wires (black and blue) as is.
Unscrewing the fan is a bit tricky.
I will measure if there are any issues with the temperature over time and will report if any.
![1677488050910.png 1677488050910.png](https://diysolarforum.com/data/attachments/137/137049-e0fc8c0baded51b3214d77e04ee8e579.jpg)
![1677488124176.png 1677488124176.png](https://diysolarforum.com/data/attachments/137/137050-6bfcfb2bef8ff83cea2504c5296ebdf3.jpg)
![1677488169703.png 1677488169703.png](https://diysolarforum.com/data/attachments/137/137051-c09dedf1b35316ab8273db7835a3823d.jpg)
![1677488216982.png 1677488216982.png](https://diysolarforum.com/data/attachments/137/137052-eefa9b68660efe54ae1b82e481f06ad1.jpg)
+ cheaper
2) Use silent fan
