I have an extra Growatt 5000es. I have a large generator that is not connected since I converted to solar. I am trying to think of a good way to have the generator available as a last resort. My idea is to configure the spare inverter as 80a grid charging with zero solar charging. Not connect it in parallel with others. Just stand alone with its 240vac source directly connected to the generator. If it so happens that the power is out and batteries starting to run low I would go start genset and turn on that inverter to just push 80a into the batteries WHILE the paralleled set of inverters run the house from the same set of batteries. Is their something wrong with my thinking?
The though is that the generator is more than capable to handling any load I could ever put on it BUT it drinks 1.5 gallons an hour. If I hook it to the battery charger and charge the batteries at high current then I'm getting the most out of that fuel. If I run the house from the generator then it's not loaded heavy and only useful while it drinking fuel. If I'm charging the batteries then I could fill the batteries in a couple hours and run my house from them for several hours. If I had a larger battery charger then I'd use it but I don't have more money to throw at this and have the spare inverter. This would cost me under $100 in wire.
