Mentioned in post 5 - Mr. Cool DIY series. Costco has sold them, Home Depot, various other retailers, in fact I thought I saw a link in one of Will's templates. Ingram's Air and Water is the US distributor for the Miami importer. I've spoken with both entities about their products and distribution.
Ingram's has them in stock and shipping is included, provide technical support and warranty service. The DIY line is the only split unit I'm aware of that will warrant units installed by the homeowner - all others exclude that. And really, unless you have the gauges and tools and tanks and such, you need a HVAC tech to setup a standard split unit. As mentioned, some techs will provide this service for an owner installed system.
I decided to give one a try after being bombarded by HVAC sales people. Especially since the old gas furnace still worked great. When you replace an air unit in a conventional central ducted system you have to replace the air handler, so it makes sense to just replace everything. Our old central system was a Sears Roebuck from about 1971. Super loud and a real power hog. It finally quit. Probably just needed a motor capacitor, but I just threw in the towel. Ended up removing it, and the air handler over the furnace, and buttoned everything back up and left the furnace. It is running as I type this. ?
Anyway, I was so happy with the 2-ton unit I decided to replace the window unit in the back wing of the house. I got a 1-ton scratch-n-dent unit from Ingrams for $800, fixed it and installed it, and it's been fantastic. Like I say, it will freeze you out. It's on a 120VAC circuit.
My middle daughter is a commercial electrician, so she was able to tell me how to reconfigure the 240circuit from the old AC unit to where the main 2-ton outdoor unit was installed. Installed a circuit box and breakers, ran wire, outside disconnect next to the new condenser unit.
Couple'a pics of installing it. The hardest part was getting the rather large air handler up 10' with the lineset - we have 15' ceilings. The smaller 1-ton unit was much easier to install.
Hole for lineset - the hardest one was thru the outside stucco wall - it was over an inch thick!
Air handler up a ladder. The earlier style DIY units came with the lineset attached to the air handler - what a PITA. They come with quick-connectors now.
Outside condenser:
