Hi, I woke up this morning and was getting error 58 (battery communication error). The battery seems to be out of juice and probably went to 0% charge despite parameter 4 (switch to utility if battery reaches a certain voltage) setting on the inverter to 43.6v (which has been the original default setting). I checked and the AC input breaker is on. Not sure why it did not switch to utility. Very confused.
Does anybody know how to wake it up?
The manual says press the button for 3s but I’m not sure which button it is referring to (see attached).
Thank you!
Thank you!
