Sunsync and Fogstar
xcentric
Learning, fast and slow.....
UK
Does anyone know if the Sunsync inverters work with Fogstar 15.5kW battery packs? I think the protocol is the same as Deye which is Pylon-compatible, if that helps....
Ask Fogstar or Sunsync directly and the answer becomes part of the terms and conditions of order as you relied on the answer before purchase.
have asked both - but if anyone knows, it'd speed things up :)
They do.
Fogstar batteries are rebadge seplos Mason kits, the same as I am running with my Sunsynk 12k 3 phase inverters
Might be a version 3 of the seplos BMS for their wall mount/standing batteries.
Works too, however I prefer the version 2 (10e)
There are a number of topics here regarding fogstar and deye/sunsynk
Their site says they use a different BMS than the Seplos one for their own branded battery.
Ah I see they changed to pace BMS...
Will work just as good..
Do a forum search SOK and sol-ark.
I posted above a link to the instructions for the pace and sol-ark/deye/sunsynk, generously made by @HighTechLab for his sok batteries
I'm new and didn't understand it :(
I'll share with my installer - he may have a better chance,
I got the idea its the pinout on the cable that needs to be sorted.
Then on the inverter side, canbus will be on pin 4 and 5
Here is an example by solar assistant for the split port.
Battery should be connected to the BMS port.
Then follow the SOK manual
Does the Fogstar / Seplos Mason kit battery also use pins 4 & 5 for the CAN Bus, IE pin to pin cable? (I think I have v2 BMS purchased Sept 23). I have not found much info on the kit other than the assembly youtube videos.
From the seplos manual ( to be found in the resources section here on the forum )
