TheGriz
More Power Scottie!!!
- Feb 17, 2020
- 128
I was hoping to report that I scored a good value on a Suredom 2000w/4000w Pure Sine Wave Inverter at $159. NOPE!!! I should have know better with a High Temp Shut Off Spec of 75C...that's HOT!!! But I simply didn't know better being a noobie.
So after testing at 1700 watts constant load (not even close to the rated 2000 constant watts) from a portable heater and heat gun and 185amps from battery lead into inverter, I see rising temps on bottom of case (had inverter elevated so I could take temp on all four sides. How high will it go...60C...65C...70C...75C, and now waiting for shut down. Didn't happen!!! I see 77C and hear POP-POP-POP, see SPARKS SHOOTING OUT of cooling fan (yes fan kicked on at 45C), and see SMOKE COMING OUT of front AC side of inverter!!! Time to scramble quickly, and remove leads from battery, and throw this very hot POS out in the back yard where it could only singe some grass.
So bottom line...I feel very lucky I proofed this garbage under test conditions, rather than it failing during real life conditions where it could have resulted in disaster!!!
Do not be tempted to buy this POS:
suredom.en.alibaba.com
I am learning new stuff every day with this LiFePO4/solar experiment!!! And it seems I'm learning the hard way...........
Hope all are well out there!
Mike
Wholesale 2000w Dc 12v 24v Pure Sine Wave Solar Inverters Converters Voltage Converter 12 V 220v With Digital Display - Buy Voltage Converter 12 V 220v,Inverter Power Inverter 12v 24v 220v 2000w 48 Volts Dc 220 Volts Ac Inverter Pure Sine Wave Voltag
Wholesale 2000w Dc 12v 24v Pure Sine Wave Solar Inverters Converters Voltage Converter 12 V 220v With Digital Display - Buy Voltage Converter 12 V 220v,Inverter Power Inverter 12v 24v 220v 2000w 48 Volts Dc 220 Volts Ac Inverter Pure Sine Wave Voltage Converter 110v To 220v,Pure Sine Wave...
Mike
