sunrise
- Jul 16, 2020
- 206
Hi all,
In my to be built system (200-300w panels + Victron SCC + 200ah Lithium battery + JBD BMS) I plan to have a disconnect switch for the battery. With that in the off season (long, wet winter in PNW) I can disconnect the battery and leave the battery in storage mode. This switch also allow quick disconnect the entire 12v system in the trailer should anything go wrong.
Also even without this switch, from time to time I will need to take out the battery and access the space beneath the battery.
But after reading some posts seems like it's a bad idea to have battery disconnected while having SCC still connected to solar panels, seems like there are design using BMS controlled relay. But I have not found the schematics include this design from any of Will's blueprints, any link to this design would be much appreciated.
Of course I could always add another switch to disconnect SCC from panels, but for that I'd have to remember to disconnect things in correct order and I'd rather have a simpler way to handle this.
Thanks,
Thanks,
