RussNM
Just be wary of those.. they can and will cause lots of death and other negative effects to you and your body. I can only assume that the only way to not make those less scary is to remove the meter which I highly recommend not doing. just be careful.The more I look in my panel, the more it seems like the 60 amp breakers are the main shut off, which is kind of not really a shut off because the two scary braided aluminum wires are still hot.
