Hello bright minds,
I have a fundamental question that I have been to embarrassed to ask, and it has me worried every since I asked in other post about paralleling batteries and I was shown a thread where a guy's house burnt down. Like all of us I don't want that to happen! I build packs such as these: 16S LEV60 LFP in a custome box with JBD BMS.
Since I am new at building packs this was a nice easy way for me to ease into building packs, and there's a detailed video on youtube on how to put it all together. I'm working on my 5th and final box of this type, then its on to my own customer pack builds with no templates of any kind.
I am scared of and have questions about thermal runaway and well...fire!
1. In a dead short or internal short of the battery, what happens in a series connection, the battery vents yes? Is that it if its able to vent? This is for just one battery and we are assuming the BMS and breaker on the box fail/dont work. Does the pack just become 15S? What exactly happens or can happen? (I know this is very situational but please give me some examples.
2. Dead short/internal short due to the protective covering of the batteries tearing and touching --I know this is more serious now we have 2 batteries that are in a scary condition. Again lets assume the BMS/breaker fail or dont work. What happens? Thermal runaway and fire at that point?
3. Now lets assume the BMS and breaker work -- what impact (if any) would they have on #1 and #2 scenarios? In particular to the battery pack.
4. If you take a look at that link and poke around a bit, you will see that it uses a PCB for all the connections. Meaning after I put the batteries in and tighten the compression plates the only wires I have to rig up are main postitive and main negative from the PCB to the the BMS which goes out to the terminals outside the box. I'm concerned in a internal short situation the PCB would just melt and become one giant conductor and just bad news bears. Unfortunately the company who sells this stuff while they are great people dont sit there and provide technical support such as this, it is very much sold as a DIY disclaimer. They have a FB group where I guess you can ask questions but I don't have an account and don't really wanna make one, I will if I have to.
I wanted to put FR-4 boards in between the batteries as extra protection but the tolerances of the box/compression plate don't allow it, they are too think (I bought .4 mm plates). Then I was going to use fish tape and measured that at .2mm so that wouldn't work either. I have been left using Kapton tape to add another layer of protection between the batteries, I simply can't make them fit with anything more. I did double up the kapton on all 8 edges of the batteries as I've heard that is the weakspot.
The packs themselves dont move around much in the house, they have their own metal cart with wheels to be moved around the house for charging or powering something ect.. batteries are brand new, the IR was almost identical on all of them, and they balance during charge/discharge to 3ma. There was a lot of talk of T-fuses in the other post but that was due to the fact I was asking about parallel batteries. In this case since its just one big series pack, what does a T-fuse get me if there's a problem with the batteries themselves? Ok the fuse blows, but the batteries physical situation hasn't changed, with a blow fuse it just can't pump that out the pack. If need be I'm willing to drill a hole on the top of the box to add a t-fuse to the top of the box, but just dont see what I get outside of maybe protection of downstream items which is pointless if the 16S pack is going burst into flames.
Would love to hear opinions on this. Is the steel enclosure enough? I mean this not super thick and if a fire broke out it would be HOT and I'm sure melt the metal. I've been thinking of adding some temperature probes to the outside of the box in various places and measure the temp, if it gets higher than a certain level, set off an alarm I can hear so I can react. Packs are only used when someone is home and never have even a remotely high load ( less than 100w ). So I can't imagine its stressing the batteries hard. The BMS unfortunately has no BT or wireless monitoring capability. I'm good with microcontrollers so I can rig some up with temp sensors to essentially act as a fire/ heat sensor to warn me. I purchased a 55lb bag of CellBlockEX, if you are not familiar with it, its designed to put out Lithium Ion fires. I figured between extengishers and that stuff I could dump on the pack if god forbid something when south it should stop things.
Like I said I have the T-fuses on hand, cost me a fortune. I also bought one (just to test it out) terminal mount style fuse (I know its nowhere near as good as t-fuses) from Blue Sea Systems. It actually mounts very nicely to the outside of that enclosure. So with that installed I have the BMS, a cheap breaker that is part of the kit I dont trust, and a fuse on the terminal. In my mind none of this stops the batteries themselves if things go south, maybe if only one goes bad. I dunno am I over thinking this. This fire thread that was shared got in my head. I'm not doing parallel batteries. Please take a look at the link I shared (safe I promise) so you can see the box, PCB and batteries ect.. that are used in the build so you have an idea with with I'm working with. If I need to enclose the whole box in firebricks or something else I'll do it. Like I said I'm on my 5th and final one of these builds, working on the kapton tape wrap of the batteries now. Then its done and then its on to more conventional style builds (using wires between each battery ect..).
Thanks in advance folks![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Cyberfed
Cyberfed
