This is what 60KWH looks like
Austenpowers
Australia
Hello
Just an update here is a pic of my battery build so far
60 odd KWh of pure fire burning lg chem cells
Will do everything to safe guard my self from this .... the box will have a double lined cement sheet cover with insulation in between the layers to keep cold and heat out...
I'm up to the big cables and bus bars hopefully not to long till I top balance and run these on my home
How do you know these aren't defective modules that came off Chevy Bolt EVs (the ones that caused fires and a massive recall) ?
I'm mean it's one thing to use second hand Lithium Ion packs, but whenever I hear LG CHEM, it makes me worry...
I do have to say that it looks pretty compact for 60kWh. Probably due to the higher energy density of those Lithium-Ion, compared to LFP.
There is a reason they are so cheap, no one wants them anywhere near a home. When something goes wrong, some home made box will do nothing to save the house.
Please do some research on this, like the dreamliner ( Boeing 787 ) that grounded the fleet. On top of this you have cells from a manufacture that has recalled basically 100% of it's production used in EV and ESS systems.
Remember...
The Bolt fires happened at home slow charging...
The batteries just burst into flames and couldn't be put out.
I wouldn't want them in a home solar setup.
What is your configuration? 100S or 5 parallel 20S?
What are the breakers at the bottom of the modules? Is they can break high amps (Interrupting Rating over 5kA, in DC of course)?
Beware of cable routing issues. I see that they are not in place yet, but be sure all positives are the same length, and all negatives are the same length… route the longest one neatly between the cells, well protected from any abrasion, then make ALL the same polarity cables the exact same length…
This is important in theory, but without knowing the current pull by each battery in parallel, the reality can be different.
It seem that Austenpowers build a 74V battery, so except if it goal is to pull 40 kW from this one continuously, those cable are way to big for nothing.
I would like to know what will be connect to this battery, but I guess there is chance those heavy cable will pass less than 30A only.
That is still 11 000W (74V x 30A x 5)
I would put these outside in a small concrete bunker with ventilation and only the feed cables going into the main building...
By the way, what do you think of this DIY grid tie inverter project? https://jamesfotherby.com/index-page/600w-grid-connected-inverter-v5/ I am thinking of building one to learn about inverter design and couple it with very cheap 12c/w used panels to save money on power bill (for a friend). This will not be getting inspected obviously.
Buy a used UL1741 inverter if you want to "learn" is my short response
Bit longer opinion ( you know the saying about opinion's and the lower rear anatomy? )
Grid-tie inverters are a dime a dozen, and one need foundational electronic and power electronics education before venturing into the weeds of circuit design and grid energy injection devices.
What exactly are your goals in this education? what skill or degree's do you have in power electronics before tackling something like the link above?
My 1.587 cents is this isn't anything 99.9999% of the population should be tinkering with, if you feel your the remaining 0.0001% then you don't need to consider what I wrote
Every cable is the same length +- 5mm
Heavy cables are double insulated and same length +- 5mm
