I'm in the process of thinking about our next system & have come up with some ideas about priorities. Longevity and durability are top of the list for me and then budget, although this doesn't need to be a low cost set up, I just don't want to throw money at problems. I'm looking at around, 2000W of panels 24V in series and the Morningstar TriStar TS-60 PWM. Our needs are small, we currently have 460 W of 12V & we ran our genny for charging about 4 or 5 hours last winter. We want to add a fridge/freezer that's rated at .0500 Kwh a day. The weather here is a mix of continental & Mediterranean, hot summers and cold, clear winters, although this is changing. We have the panels on the roof of an outbuilding - a almost flat roof with a rack atttched - & battery etc. inside, so it exposed to temperature changes, although it doesn't see extremes inside there. Because of this I'm thinking about the Morningstar TS , a unit with a reputation for robustness, a working temperature range of -40c to +60 c. So why a PWM unit instead of a MPPT ? Price - the PWM is on offer for €279 & the MPPT is €854 Am i wrong about this ? is it worth spending 3 x as much for small gains ? At the moment we have a %20 DOD on average, in a cycle & plan to size the battery bank for the new system the same. Our backup is usually run when the battery is at %50 discharged.
