Two EG4 PowerPro Wallmount communication with Sol-Ark 12k
K2mannn
I am expecting to pick up from the port two EG4 PowerPro Wallmount 14.3kWh batteries to tie to my Sol-Ark 12k system. Sol-Ark said be sure the battery address is CANbus address 00. EG4 shows the DIP switches labeled backwards from normal convention (all 8 switches ON EG4 calls 00, the convention is all 8 switches OFF = 00. What do I use for my system?
It’s in the manual. But all dip switches up to select solark Can protocol. Then the master battery has dipswitch 1 down. Then set battery 2 for id 2. On the solark you select BMS 00 not the battery.
Here is a video showing how to select protocols and set master battery for close loop
Thanks I had already watched that one.... great minds think alike
