Hi I just installed a second identical (consulted with seller) EASUN Axpert 8KW in parallel yesterday. The first one was working like a charm for 6 months. I have 2 JBD BMSs behind a 250A resettable fuse. Today during the day and modest solar production (9kw across 4 strings) the 250A fuse tripped and the power was cut. I went to check and both inverters were dark/dead. No smoke or smell. I tried turning resetting the fuse couple of times but it tripped each time. I then measured 0.16-0.19ohm on input to both inverters. Tried connecting both via 8ohm 50w to charge up but they would just continuously consume the power afforded by the resistor and never charge. It seems that both inverters are shorting their respective battery terminals.
I cannot wrap my head around how two of them failed at the same time and why both failed the same way. I would have imagined even if one shorted the other one would trip or something. But it seems both are dead and both are shorted. This is an off-grid installation so I am not looking forward to the next few days. Any ideas/thoughts ??? I am quite acquainted with a soldering iron or a scope
The bloody irony is I bought the second one to increase reliability in case the original one failed. Day later I am with no power...
