RoySalisbury
- Apr 24, 2022
- 136
In general I know that you should wire panels so that they balance out voltage. However, I recently lost a single panel in an array of 12.
What would be the result of wiring them up into two strings .. one with 5 panels and one with 6. Right now I have had to go down to 10 panels, and would like to get the other into the mix instead of sitting there as a "spare".
The specs for the panels are as follows:
Axitec AC-330P/72S (12)
Thanks
Nominal Output (Pmpp): | 330 Wp |
Nominal Voltage (Umpp): | 37.70 Volts |
Nominal Current (Impp): | 8.76 Amps |
Short Circuit Current (Isc): | 9.27 Amps |
Open Circuit Voltage (Uoc): | 45.83 Volts |
Module Conversion Efficiency: | 17.01% |
Voltage Uoc: | -0.30%/K |
Current Isc: | 0.04%/K |
Output Pmpp: | -0.42%/K |
Thanks
