solerpowor!
- May 7, 2022
- 2
I have a grid-tied 10k system with 23 Hanwha Q.Cell monos (305W/ea; ~7kW) and some 360W polys rounding out the remaining 3k. I'm using a SolarEdge SE7600H-US. The system runs great. Total installed cost gives us an ROI of something like four years which is acceptable to me!
Anyway, I want to add a battery. There are two reasons for this:
First - I want our refrigerators (qty2) and freezers (qty2) to keep running during a power outage.
Second - I want to be able to use my solar installation during a power outage which you cannot do without a battery.
Numbers -
According to my inverter's history, I have about 9.0hrs of ~2.5kW solar exposure in August (hot/humid combo for us). This means I need to run off of a battery for up to 14h 45m in August (avg Aug temps are 105*f - 80*f with humidity) to keep the appliances running.
According to online resources, a fridge uses about 1.5kW a day. 1.5kW/day * 4 = 6kW/day. 6kW * .62 [14.75hrs of 24.00hrs] = 3.72kW to ride through the night. Does this seem reasonable?
So - the questions are:
1.) What is the most cost-effective inverter+battery combination available to deliver a 7.5-10.0kW output that will also allow a battery connection? I would prefer to have an inverter that is battery agnostic but I know most of the big brands will impose limits on the brands of batteries that I can use.
2.) Are there "silent" batteries that we can mount in a bedroom closet or will they all have an electrical hum/cooling fan that will disturb light sleepers? I want the battery in a climate controlled area instead of exposed to the elements or even in a shed if it can be avoided.
I plan to source the battery and inverter independently and hire out the install unless it's something that can be done DIY.
Alternatively, is there a way to install second a small inverter and dedicate some panels to charging batteries and powering a couple circuits that feed the refrigerators? Will this be able to keep the main inverter online during an outage? This seems like a much more complicated option.
Numbers -
