K-fab
We presently have a pair of Fronius Plus inverters with 70 250W (total of 17.5kW) panels powering our house.
Located in North Scottsdale, AZ. The sun abounds.
We feed back into the grid from approximately 10:30 to about 5, at least during the summer months.
June, July and August (peak usage months) our APS bill shows that the daily power consumption for the house is about 95kWh. (just under 4kW per hour average). This is what I based my numbers off of. Worst case scenario.
The peak usage is when the solar starts dropping down and the AC systems (three units, each programmed to be as efficiently used as possible) have to work to cool off the day's heat saturation. We also have an Audi etron that we try to charge during peak hours (30 amp input). We try to use things that load the system during peak production times.
I'm wanting to add battery storage ability. The Fronius does not have this (it's 10 years old now).
Have been watching a lot of Will's videos and have come to the conclusion that this system will probably suffice but I'm not quite sure of the math to prove it:
Here's what I'm thinking, please correct/guide me.
EG4 18kPV inverter ($4,900). - https://www.currentconnected.com/product/eg4-18kpv-hybrid-inverter/
EG4 Wall Mount indoor battery 48V, 280Ah, 14.3kWh ($3,300) - https://signaturesolar.com/eg4-wall...0-year-warranty-pre-order/?ref=cPwLcVc0SW-BjN
I'll pull about half the old solar panels and replace them with Aptos 370W bifacial panels. A pallet (31 units at a cost of $3,300) has a total of 11.47Kw - https://signaturesolar.com/11-47kw-...a-120-bf26-370w-full-pallet-31-11-47kw-total/
Is this overkill?
Should I consider using one of the EG4 12kPV inverters ($3,500) instead of the 18kPV? - https://www.currentconnected.com/product/eg4-12kpv-48v-hybrid-all-in-one-inverter/
Do I keep the present solar panel array and just upgrade the inverter and add battery storage?
I'm not concerned with going fully off grid but I'd like to be able to offset the power used at night and the closer to off grid the better.
Right now with the above listed items I'm at about $11,500 investment so my payoff would be roughly 2.75 years. My last 12 months worth of APS bills total about $4,000.
If I just went with the battery and the 12kPV the cost of the system would be about $6,800. (shipping not included in any of my pricing).
So let's hear everyone's thoughts. I'm fully open to suggestions and comments as I'm just now starting to really get serious about upgrading.
Corrected my panel wattage. Climbed up and took a look. They're 250W so I have a total of 17.5kW of PV. That's more than enough.
Is this overkill?
