('Battery Monitor [279]', 'Voltage', 'V')
('Battery Monitor [279]', 'Starter battery voltage', 'V')
('Battery Monitor [279]', 'Current', 'A')
('Battery Monitor [279]', 'Consumed Amphours', 'Ah')
('Battery Monitor [279]', 'State of charge', '%')
('Battery Monitor [279]', 'Time to go', 'h')
('Battery Monitor [279]', 'Low voltage alarm', '')
('Battery Monitor [279]', 'High voltage alarm', '')
('Battery Monitor [279]', 'Low starter-voltage alarm', '')
('Battery Monitor [279]', 'High starter-voltage alarm', '')
('Battery Monitor [279]', 'Low state-of-charge alarm', '')
('Battery Monitor [279]', 'Low battery temperature alarm', '')
('Battery Monitor [279]', 'High battery temperature alarm', '')
('Battery Monitor [279]', 'Mid-voltage alarm', '')
('Battery Monitor [279]', 'Deepest discharge', 'Ah')
('Battery Monitor [279]', 'Last discharge', 'Ah')
('Battery Monitor [279]', 'Average discharge', 'Ah')
('Battery Monitor [279]', 'Charge cycles', '')
('Battery Monitor [279]', 'Full discharges', '')
('Battery Monitor [279]', 'Total Ah drawn', 'Ah')
('Battery Monitor [279]', 'Minimum voltage', 'V')
('Battery Monitor [279]', 'Maximum voltage', 'V')
('Battery Monitor [279]', 'Time since last full charge', '')
('Battery Monitor [279]', 'Automatic syncs', '')
('Battery Monitor [279]', 'Low voltage alarms', '')
('Battery Monitor [279]', 'High voltage alarms', '')
('Battery Monitor [279]', 'Minimum starter voltage', 'V')
('Battery Monitor [279]', 'Maximum starter voltage', 'V')
('Battery Monitor [279]', 'Discharged Energy', 'kWh')
('Battery Monitor [279]', 'Charged Energy', 'kWh')
('Solar Charger [0]', 'Voltage', 'V')
('Solar Charger [0]', 'Current', 'A')
('Solar Charger [0]', 'Battery watts', 'W')
('Solar Charger [0]', 'Battery temperature', 'C')
('Solar Charger [0]', 'Load state', '')
('Solar Charger [0]', 'Charger on/off', '')
('Solar Charger [0]', 'Charge state', '')
('Solar Charger [0]', 'PV voltage', 'V')
('Solar Charger [0]', 'PV power', '')
('Solar Charger [0]', 'MPPT State', '')
('Solar Charger [0]', 'Relay on the charger', '')
('Solar Charger [0]', 'Low batt. voltage alarm', '')
('Solar Charger [0]', 'High batt. voltage alarm', '')
('Solar Charger [0]', 'Yield today', 'kWh')
('Solar Charger [0]', 'Maximum charge power today', 'W')
('Solar Charger [0]', 'Yield yesterday', 'kWh')
('Solar Charger [0]', 'Maximum charge power yesterday', 'W')
('Solar Charger [0]', 'Error code', '')
('Solar Charger [0]', 'User yield', 'kWh')
('Solar Charger [0]', 'PV Yield Solar Charger Forecast', 'Wh')
('Solar Charger [1]', 'Voltage', 'V')
('Solar Charger [1]', 'Current', 'A')
('Solar Charger [1]', 'Battery watts', 'W')
('Solar Charger [1]', 'Battery temperature', 'C')
('Solar Charger [1]', 'Load state', '')
('Solar Charger [1]', 'Charger on/off', '')
('Solar Charger [1]', 'Charge state', '')
('Solar Charger [1]', 'PV voltage', 'V')
('Solar Charger [1]', 'PV power', '')
('Solar Charger [1]', 'Solar charge current limit', 'A')
('Solar Charger [1]', 'MPPT State', '')
('Solar Charger [1]', 'Relay on the charger', '')
('Solar Charger [1]', 'Low batt. voltage alarm', '')
('Solar Charger [1]', 'High batt. voltage alarm', '')
('Solar Charger [1]', 'Yield today', 'kWh')
('Solar Charger [1]', 'Maximum charge power today', 'W')
('Solar Charger [1]', 'Yield yesterday', 'kWh')
('Solar Charger [1]', 'Maximum charge power yesterday', 'W')
('Solar Charger [1]', 'Error code', '')
('Solar Charger [1]', 'User yield', 'kWh')
('Solar Charger [1]', 'PV Yield Solar Charger Forecast', 'Wh')
('Solar Charger [278]', 'PV Yield Solar Charger Forecast', 'Wh')
('System overview [0]', '#1 Low SOC; discharge disabled', '')
('System overview [0]', '#2 BatteryLife is active', '')
('System overview [0]', '#3 Charge disabled by BMS', '')
('System overview [0]', '#4 Discharge disabled by BMS', '')
('System overview [0]', '#5 Slow charge is active', '')
('System overview [0]', '#6 Charge disabled by user setting', '')
('System overview [0]', '#7 Discharge disabled by user setting', '')
('System overview [0]', 'PV - DC-coupled', 'W')
('System overview [0]', 'AC Consumption L1', 'W')
('System overview [0]', 'AC Consumption L2', 'W')
('System overview [0]', 'AC Consumption L3', 'W')
('System overview [0]', 'Grid L1', 'W')
('System overview [0]', 'Grid L2', 'W')
('System overview [0]', 'Grid L3', 'W')
('System overview [0]', 'DC System', 'W')
('System overview [0]', 'Voltage', 'V')
('System overview [0]', 'Current', 'A')
('System overview [0]', 'VE.Bus charge current', 'A')
('System overview [0]', 'Battery Power', 'W')
('System overview [0]', 'VE.Bus charge power', 'W')
('System overview [0]', 'Battery SOC', '%')
('System overview [0]', 'Battery state', '')
('System overview [0]', 'Battery Consumed Amphours', 'Ah')
('System overview [0]', 'Battery Time to Go', 'h')
('System overview [0]', 'DVCC Multiple batteries alarm', '')
('System overview [0]', 'GX Error #48 DVCC with incompatible firmware', '')
('System overview [0]', 'No grid meter alarm', '')
('System overview [0]', 'AC-Input', '')
('System overview [0]', 'Consumption Forecast', 'Wh')
('System overview [276]', 'Grid alarm', '')
('Grid meter [30]', 'Grid L1 - Power', 'W')
('Grid meter [30]', 'Grid L2 - Power', 'W')
('Grid meter [30]', 'Grid L3 - Power', '')
('Grid meter [30]', 'Grid meter voltage L1', 'V')
('Grid meter [30]', 'Grid meter current L1', 'A')
('Grid meter [30]', 'Grid meter voltage L2', 'V')
('Grid meter [30]', 'Grid meter current L2', 'A')
('Grid meter [30]', 'Grid meter voltage L3', 'V')
('Grid meter [30]', 'Grid meter current L3', 'A')
('Grid meter [31]', 'Grid L1 - Power', 'W')
('Grid meter [31]', 'Grid L2 - Power', 'W')
('Grid meter [31]', 'Grid meter voltage L1', 'V')
('Grid meter [31]', 'Grid meter current L1', 'A')
('Grid meter [31]', 'Grid meter voltage L2', 'V')
('Grid meter [31]', 'Grid meter current L2', 'A')
('Grid meter [32]', 'Grid L1 - Power', 'W')
('Grid meter [32]', 'Grid L2 - Power', 'W')
('Grid meter [32]', 'Grid L3 - Power', '')
('Grid meter [32]', 'Grid meter voltage L1', 'V')
('Grid meter [32]', 'Grid meter current L1', 'A')
('Grid meter [32]', 'Grid meter voltage L2', 'V')
('Grid meter [32]', 'Grid meter current L2', 'A')
('Grid meter [32]', 'Grid meter voltage L3', 'V')
('Grid meter [32]', 'Grid meter current L3', 'A')
('Temperature sensor [24]', 'Temperature', 'C')
('Temperature sensor [24]', 'Temperature status', '')
('Temperature sensor [25]', 'Temperature', 'C')
('Temperature sensor [25]', 'Temperature status', '')
('Temperature sensor [26]', 'Temperature', 'C')
('Temperature sensor [26]', 'Temperature status', '')
('DC Source [278]', 'Battery Voltage', '')
('DC Source [278]', 'Generated Current', '')
('DC Source [278]', 'Total energy produced', 'kWh')
('DC Source [278]', 'Low voltage alarm', '')
('DC Source [278]', 'High voltage alarm', '')
('DC Source [278]', 'Low auxiliary voltage alarm', '')
('DC Source [278]', 'High auxiliary voltage alarm', '')
('DC Source [278]', 'Low temperature alarm', '')
('DC Source [278]', 'High temperature alarm', '')
