Hi Travis, great post and information! I am based im the Uk and looking to get a u27-12xp for my camper. I can only find black ones which only have a 130ah capacity. I wondered if you had any thoughts or opinions on the black ones? Are they mostly the same? Worth trying to get a green one? I cantnfind5a data sheet anywhere!
I don't have any experience with the black ones. The manual for the green ones does mention it's upgrades over the black ones. It says. "
3. U-CHARGE REVISION 2 CHANGES AND UPDATES
3.1. U-Charge Rev 2
U-Charge Battery Modules:
• Communication cable connectors are now Amp Superseal automotive grade connectors
• Electrical and software backwards compatibility
• Communication cables and electronics are now field replaceable.
• Event logging capability has been added to the Battery electronics
• Balance current has been increased, reducing balancing time
• The handle on the U27, U24, and UEV models is now replaceable and removable
• The indicator LED is now moved to be more accessible when hold down features are used in a
system
• Module serial numbers are reported to the BMS
• Tamper proof features on the enclosure
Battery Management System (BMS):
• Fully sealed case to protect connections
• All low voltage communication, signal, and control lines are made through Amp Superseal
Accessories:
• Over molded bus termination connectors available
• Inter-battery bus supply voltage booster for large strings, available
• Communication connector adaptor for backwards compatibility to Rev 1"
