OneStudPuppy
- May 18, 2022
- 84
So new controller is supposed to be here tomorrow, but something I keep thinking about is in a mobile fiberglass trailer towing and rough roads and highways bouncing.
If you look at scamp, casita, trail mite (13 ft actual egg about 10 feet) etx. These things are maybe 1000 lbs. when I brought my trailer home catching some pot holes etc on freeways. The trailer has a pretty strong tendency to bounce. There was enough bounce to knock curtains down.
So I am trying to brainstorm the mounting I will go with on this shelf and wonder if I should add some dense foam or something under it before I secure it to the shelf?
Better to disconnect and carry in pickup until at camp? I’d like to figure some way to minimize potential shocks to the battery to not break loose any connections internally etc.
Open for any input and ideas suggestions etc.
Pic below of where more than likely the battery will be mounted, controller will be different that one in the picture was a factory dud and I’m switching to a rover for ppt and lost any faith at all in the wander series.
