CamaroMan
- Nov 26, 2022
- 44
Hi, so i just pretty much got the core setup installed. I could not run a darn thing. Finally tracked it down to the BP220 i just put in. I have a 250AH battery at 24.4v, when i bypass the BP220 the v stays pretty stable and no alarms. With it connected the V drops to 14v, like it cant pass thru the amps?
2500w 24v LF toroid inverter. It was a used amazon deal and i thought maybe just an open box but maybe someone damaged it? And no i have NO charge at all on or donstream from the OUT terminal.. my solar controller is hooked up the the batt/In circuit..
Is there a limit on the inverter size? 24v @ 220 amps should supply enough current correct? I am ordering a replacement - this looks like someone had already connected and possibly made a mistake or blew it somehow..
