Victron multiplus(es) vs. eg4 6000xp?
solarDavesolar
North America, Earth
I have a fully off-grid 48v system and I'm looking to upgrade the inverter.
My main purpose is charging an EV and while I don't care how fast the car charges, I am trying to maximize the electricity that actually gets into the car's battery because my system is panel constrained.
My current setup works but is bottlenecked by my Victron Phoenix 48/1200 which can't even max out L1 EV charging (1440 watts). I have to set the car to charge at 10amps @120v which means my charge efficiency is pretty low because enabling the car's charge circuits draws a decent share of the current.
Ideally I'd like to get to something that can support a minimum constant output of 2,880 watts at 240v which seems to be a good minimum for optimizing efficiency into the car's battery.
It looks like sticking with Victron would mean I'd have to get two inverters to create 240v. Even the cheapest MultiPlus 2kVA at $940 should work for my needs but doesn't leave much room to upgrade in the future.
And two multipluses is $500 more than the EG4 6000XP at $1,450 which comes with 240v out of the box.
I realize the eg4 has a high frequency inverter vs. the LF in the victron and victron has a better reputation, but it's tough to pay more, have to buy more wiring, find locations for mounting screws etc. for the same capabilities.
Any recommendations one way or the other? Or is there anything else I'm overlooking?
Here's what I'm currently eyeing.
$940 - Victron 48V MultiPlus 2kVA Inverter – 25A Charger
$1450 - EG4 6000XP Off-Grid All-in-One Inverter/Charger
And if I go Victron, is there a super compelling case to go for the UL listed one with a little more headroom?
$1275 - Victron 48V MultiPlus-II UL1741 3kVA 120V Inverter 35A Charger
Thanks in advance!
Thanks in advance!
If you only need to feed the EV charger at 3kW and 240V you could get a Euro spec Victron multiplus 2 or quattro which are 220/240 in a single unit. A mp2 3kVA is 2400W with a power factor of 0.8, maybe the EV charger is closer to 1.0 but you'll prob need to step up to a 5kVA model to achieve what you are looking for. What does the battery bank consist of?
I almost suggested this, but I don't know how the grounds will play. If completely isolated, it's probably fine provided the car doesn't care if the ground isn't 120V to ground from each of the 240V conductors.
Maybe @timselectric knows more.
There are even cheaper inverters I would consider if this is an option. IRRC, PowMr has a 230V 5kVA AiO unit for about $500 that also includes a MPPT.
Found it...
Found it...
It would probably work with an EV charger for the European market.
But not for one designed for North America.
Because it would be checking for the split-phase ground.
Not saying that it can't be done (I'll be doing it).
But some modifications will be required.
If I had an EV and just needed dedicated charging for it, would def go with big euro Victron 220/240 plus the precious, integration with Cerbo yes please.
Found it...
Just bananas pricing the 3800W unit is $260 after coupon...
Victron also makes an autotransformer to provide 120/240V split phase either from a 120V or 230V EU inverter.
32A AT is 481 EU., so that + 48/3kVA would put you just a hair over the 6000XP.
If you don't need to pass an inspection, UL = meh.
The EU spec inverter + autotransformer is an interesting option, thanks!
Looks like Signature solar has the 32a Autotransformer at $452 and a place called icmontana dotcom (anyone ever heard any feedback on them?) has the MultiPlus-II 48/5000/70-50 230V for $1030.
That seems like it'd get me a pretty robust system and if I'm reading correctly, I can still get a 120v circuit out of the AT, right? EV charging is my main use but having a 120v battery backup is one of the key points of this system.
And the battery is currently a single 5.1 kWh eg4 battery. That's one of the reasons I want to keep the EV draw as low as possible while wasting the smallest amount of energy possible.
Hi, long time lurker here, first post.
can I say, using an autotransformer may not be a good idea, European spec inverters will likely expect one side of the 230v to be earthed - or even do it automatically, autotransformer will be centre tapped earth. (BANG!!)
Surely better to use European spec charger . Then use a 120v autotransformer for smaller loads (which as it is only one " leg" shouldn't cuase problems. Also saves transformer losses on your (likely) biggest load.
would suggest maybe the chargers with a 16a plug on,which should handle 3Kw fine . Avoid the UK spec 13a ones.
Split phase AT are designed to address this. EU single phase inverters feeding split phase AT is a relatively common solution.
Not sure how an autotransformer design could address that, only a "real" transformer could, and for that sort of power rating = expensive. Why not use a European charger, would likely be cheaper than the transformer on it's own? Such as ...
This one can set the charging current to a choice of settings.
Not sure what the import costs would be though.
