If I pull the negative it will shut down my system which is not a problem for testing. Shunt connects in line on the negative battery to inverter. Already pulled positive small cable for 1/2 a day with no change.I can only recommend the obvious and check connections.
After that, pull the negative and positive wires that power the shunt, not the big battery cable, out and test them for continuity and intermittent connections. If that were the case, it would shut off.
Not possible which is why I’m asking. Inverter is running and charging fine the 48v bank. BMS and inverter is reading correctThe shunt indicates negative 300 volts.
there should be a small wire with a positive and negative going to the battery to provide power to the shunt for Bluetooth. That smaller wire is what I’m referring to.If I pull the negative it will shut down my system which is not a problem for testing. Shunt connects in line on the negative battery to inverter. Already pulled positive small cable for 1/2 a day with no change.
This has been working for the last 6 months perfectly fine. I just checked all connections and the same issue. No firmware upgrades either. Wonder if there is anyway to do factory reset or something. I’ve only seen reset history directions online
What? I disconnected for 1/2 a day (12 hours) hoping to reset. So that is not my problem.Wait, did you say you disconnected the small red wire to save 1/2 A per day ?
If so, there’s your problem.
Have you contacted Victron? Might be past time to do so.What? I disconnected for 1/2 a day (12 hours) hoping to reset. So that is not my problem.
Sure did and the vendor is FedEx’ing me a new one. Just need a picture of me destroying the broken one. While Victron is more expensive for components, can’t beat the support. Love it.
I did submit directly to Victron with the vendor name, serial, date bought, etc. Vendor contacted me within 12 hours. Victron did send an email to the vendor and myself stating they will follow up to make sure the matter is resolved. Great service.Unfortunately, this is heavily dependent on the vendor. Vendors can lose their deal if they fail to provide adequate support, but that doesn't stop them entirely. Victron does have a way to "encourage" a vendor to provide the support to which they agreed by submitting a support ticket through Victron to the dealer by item S/N:
This how mine is installed. I have the same shunt but haven’t experienced this problem.Not on the Victron. Only a small positive which I already disconnected for 1/2 a day. Negative comes from shunt terminals itself View attachment 131073
