Hi guys,
i have some questions regarding Victron Smartsolar MPPT charger:
1. Can i set the output voltage freely up to PV-input voltage or are there any restrictions to typical battery voltages?
2. When i have 2 Trina Solar modules in series i get Voc = 104V (at 20 deg. C). What about Winter time (-15 deg. possible) - is 150V enough reserve?
3. What is the 'auxiliary load output' ('Lastausgang' in german) - can i use it independently from the battery loading?
I heard there are problems with some microinverters (Hoymiles) where the MPPT is not compatible with the Victron MPPT and causes problems?
Can i separatly adjust the voltage of the 'load output'?
4. Option: 4 modules in series -> 208Voc, would be the 250/xx an option? What is the smallest 'xx' available, lowest current? Current relates to output current (not input), right? For me i think 40A would be enough, but smallest option is 60, right?
Thanks so much!
Cheers Rilo
Thanks so much!
Cheers Rilo
