douglasheld
I've wired up my Victron SmartSolar MPPT 75|10 with the 2.5mm^2 double-insulated cables that came with my 120W panel, and I've put square bootlace ferrules on the ends.
However, I have not torqued these connections. I aim to buy a torque screwdriver and to re-torque these connections properly to 0.75Nm per the Victron manual. The screwdriver is a bit expensive however! I would like to buy the exact right size head for this task and be done with it.
Question: Can somebody who has the same MPPT charge controller tell me exactly what size screwdriver head appears to be the most perfect fit? Thank you!
- Torque handle: https://www.ebay.co.uk/itm/325579672667
- Torque handle blades: https://www.felo.com/fileadmin/user_upload/E-Book/E-Book-DE-EN-2022/index.html (page 106)
Flat head tip size | Length | Felo stock number | EAN |
3,5 x 0,6 | 170 mm | 100 353 94 | 40071576386 56 |
4,0 x 0,8 | 170 mm | 100 043 94 | 40071576386 32 |
5,5 x 1,0 | 170 mm | 100 554 94 | 40071576386 70 |
