Hey everyone,
I removed the battery cells from my camper yesterday as I was rearranging things and noticed one was bulging and appeared to be leaking on the bottom. The others don't appear to be actively leaking but I can see some ripples and peeling around the bottom that I'm concerned about. I was curious if someone with more experience/knowledge can look at these and tell me if they're ok to keep using or I need to toss them.
These are 120ah cells I got off Aliexpress in 2020. I can't remember the seller but they had good feedback and reviews at the time. I had Gorilla tape around the bottom edges as padding, which you'll see in the photos and is why you'll see some of that residue as well as some of the black liner pulled off. Yeah, I know I should have used something else but I was on the road and just winged it :/
Here's the bad one.
Here are the others that I'm concerned about. Do I need to replace the whole lot or do these look ok? I believe the mark on the blue side of the second photo is from some rubbing before I put the tape on, not a leak.
Thanks for the input.
Here's the bad one.
