Should work fine as long as your neighbors don't call the Homeowners Association.
Cows are dumb and might step on them.
Wind could be a problem so drive some rebar in at an angle to hold the pallets down.
Get some extra pallets, cut them up to make your angle supports.
Dogs might pee on them so leave a little wire with a couple amps running through it. They will learn quickly.
Rodents may find your wires attractive so maybe you want to use conduit or loom.
Have you ever played with a magnifying glass? Getting it pointed directly at the sun results in the best focal point. Solar panels are the same.
