Renting a double wide with a solar set-up.
16 100Ah LifeP04 (ampertine) batteries (8batts =1 bank, 8 =the other bank)
1 5kw (10kw max) inverter
1 4kw inverter
2 MPPT charge controllers
This is a 12v system.
All panels are wired in series and parallel.
Unsure the specs for the panels. They might be 12 240-300w panels.
••So my questions are about what should be added to the system to make it more efficient and safe?
•Would it be better to run on a 24 or 48v configuration?
•Can't all of the batteries just be connected into a single array aka bank?
•Not needing two inverters?
•Does it need another inverter?
>that stupid jupiter inverter can't seem to hold up, it was replaced about a WK ago and now this one is making the same sound and just not working. No reset switch or button. Same amount of batteries connected and it won't even work while the 4kw inverter is doing just fine. This system is running the house maybe 200w-450w are drawing during sleeping and no one being home.
I will appreciate any and all help.
I'm seeking assistance bc I know not what I do in this field. All I can think about is safety measures I've already added an ABC fire extinguisher 3' away. I'm only used to working on simple 1 12 batteries in vehicles adding inline fuses and what not but this, this is awesome but can be a little more involved. I'm willing to learn though bc I kinda love it.
All batteries connections made with single or double O wiring.
No circuit breakers, no fuses, no safety cut offs. Kind of paranoid.
1 4kw inverter
