Hi everyone, so I'm brand new to this forum, but have been hanging around reading various posts for a few months now. I've watched a ton of videos from Will and others regarding solar, and things like this really interest me. I love the idea of not having a power bill as well. I'm looking to do a solar system with a new house we are about to build, so we will be insulating it well. We will also be choosing energy efficient appliances including a geothermal heat pump with desuperheater and heat pump water heater.
I can't go grid-tied because the base power bill here is $40 and they are currently charging over $5 per kW of solar panels per month just for having solar. For me that would be a BASE power bill of $110 ($40 + (14 * 5) before using a single watt. By my math, I'd never be able to provide enough extra power back to the grid to make up that difference since they also don't offer any time of use rates...just one flat rate for the co-op I'd have to use. Their buyback rate is what they call an "avoided cost", which is $0.05/kWh.
I estimate my power usage would be around 50 kWh per day +/-
I'd like to use 2 x 6000XP inverters with 16kW of bifacial 390w panels ground mounted. We have 28 acres.
For battery, I was thinking 60kW (12) of either the EG4 or the Ruixu(?) batteries.
I will have a 10kW propane backup generator which will burn 1.5 gallons per hour.
I'm located in central Alabama. I'd just like to know if you think this system would work. I'd really like to go this route if possible, so I'm open to any suggestions on changes to the system.
One last question I have, is I currently have a nice 4 post enclosed server rack that I'd like to use for the batteries if possible. Can I purchase just the bus bars and covers to go in it, or do I have to purchase the specific cabinets that hold 6 batteries? I'd like to avoid that cost if possible.
Thanks.
Thanks.
