Hi all. Probably a very silly question but I need help please. I have a Victron Multiplus-II 48/15000/200-100 230v Inverter. I am in France and the solar system is around 60 metres from the main house. The previous electrician cut the house cable feed and inserted two 16mm2 cables in a ring from the house now 120 metres long, into the solar shed and back to the house in a ring main. This meant that my house was now suffering huge voltage drops. The solar room wiring was intended to only run the inverter and is not back fed to the mains for income. This also meant that in any working situation on the solar area the power was cut to the house. It was my belief that the inverter would run perfectly OK with its own fused circuit from the solar room into the house mains keeping the house circuit as it was. This spur cable would be a dedicated cable. The actual house mains from the power grid is 32mm2. Other electricians here are very cautious and want to install a 50mm2 ring main which seems to me excessive. For clarity I have 40 410w panels feeding the batteries through MPPT's. Everything is new Victron and as yet I have not connected it up because I had so many problems with my old inverters. I now believe that this was likely because of power loss. Can anyone advise me please? My existing house electric consumption is conventional lighting, heating and general house connections. Only two people use the house.
