Michi
Hi all,
I'm new in this forum and I'm a swiss! Therefore sorry for my bad english!![Censored :censored: :censored:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I build my own 100Ah LiFePo4 battery with Dali BMS and set the BMS according to the datasheet of the batterie supplier. Max cell voltage 3.65V and max. battery voltage 14.4V. Now, I charged up the battery with the Renogy DC/DC MPPT charger (RBC50D1S) and the BMS turned off at 14.4V. So far so good but in my opinion this should not be the job of the BMS! In regular operation the charger should turn off before the BMS cuts the voltage. I set the charger to LFP but according to the charging parameters in the user guide the boost voltage is set to 14.4V and the charging limit voltage to 15.5V. This means all components are working in the definied range. The default values of the renogy charger are way too high for LFP in my opinion or do I understand something wrong?
Thank you in advance for your help.
Best, Michi
Best, Michi
