2 different questions,6000xp
1-If some people have blown up units due to start up rush...can you add the additional step of a manual pre charge resistor like I have,(100W20(resistor)J
and do it manually before you do the normal start up? If so ,is this resistor a good one for the purpose????A blown up inverter would be a catastrophe for me...
2-The pv instructions on the XP say that you "should/must" use 2 strings that have the same number of panels. My strings are certainly the exact same panels but 1 string is 5 panels and the other 7 panels. Is that really an issue???
thanks
thanks
